ES300 2001(automatic), 4000 rpm at 75 mph!?
Is my es300 2001(automatic) rpm too high or normal when it drives on freeway at 75 mph with around 4000 rpm? Does anyone have the same issue?
I just bought the vehicle so I have no idea. I've heard about O/D, where and what is it? Does it help in this case? This is weird. I always in drive. Tell me your rpm at 75 mph please.
O/D is 4th gear. There is a little switch below the button you use when you want to change gears. If O/D is off you will not use 4th gear and will stay in 3rd gear. And if O/D is off there will be light on the dash saying O/D off. My RX300 which has the same 3.0 V6 as your ES300 does about 3100 RPM at 75. Good luck!
my 99 ran at 2700 rpm at 80mph with stock 15s. my 2000 runs at just over 3000 rpms at 80mph with 17 in lexus is300 wheels. There is definitely something wrong if it is out of that range. please tell me that you don't have 20s on it... LOL
4mula_J87
09-09-10 07:12 AM
Zeedum
09-06-06 11:24 AM
