how to change the radio light
Old 12-04-10 | 07:15 AM
marcoes300's Avatar
marcoes300
Default how to change the radio light
hi , some light on my radio dosnt work ...
how can i change them .
also the light for the transmition ( drive, back ,,,) light dosnt work ... need help to change them too
Uploaded with ImageShack.us
tanks !
Old 12-04-10 | 08:50 AM
Kansas's Avatar
Kansas
This is what I got when I search for "radio bulb" in the ES300 section: https://www.clublexus.com/forums/sea...archid=5763265
You can do a similar search for information on replacing the shift indicator bulb -- don't know if you mean the one on the console or the one in the dash cluster. I know from experience that replacing the bulb in the console requires disassembling the shift indicator around the gear shift. It's not necessary to remove the shift lever -- just pull the shift indicator surround up the shift lever shaft a little to get get to the parts underneath. The bulb is pretty well buried but it will be obvious how to replace it when you see it.
Old 12-04-10 | 09:00 AM
01LEXPL's Avatar
01LEXPL
the shift indicator bulb is a ***** to get at - but not impossible.
I changed mine to an LED, it is a #74 bulb and very common on eBay & parts stores.
Old 12-04-10 | 09:22 AM
marcoes300's Avatar
marcoes300
ok tanks , any tutorial ? i need to get out the middle consol right ?
Old 12-04-10 | 11:47 AM
marcoes300's Avatar
marcoes300
ok done , now i need to find a place to buy the light for the heated seat button
Old 12-04-10 | 08:09 PM
sphillips's Avatar
sphillips
Did you get the seats fixed?
Old 12-05-10 | 06:44 AM
marcoes300's Avatar
marcoes300
no the seat still dont work im very desesperat !
Old 12-06-10 | 08:04 PM
sphillips's Avatar
sphillips
As far as the radio button back lights go, I purchased some 8v leds on-line and plan on repairing mine soon. You should have some experience in desoldering and soldering. If not, maybe you have a friend who can help. There is diy info on this site.
Old 12-06-10 | 10:54 PM
nine3es's Avatar
nine3es
the link in post #2 does not work for me. i have read the threads and searched but can not find the step by step diy on replacing the radio back lighting. does it require a 8v led?
i did see where someone had someone else replace the back lighting, looked great but there was no details on leds used or voltage or anything.
Old 11-04-11 | 02:58 AM
marcoes300's Avatar
marcoes300
where do i connect LED inline on the radio ?
agibson
10-24-22 01:36 PM
Megapea
ES - 6th Gen (2013-2018)
04-16-19 08:49 AM
Phil01
RX - 1st Gen (1999-2003)
11-05-18 06:19 AM
Jlee79
02-27-17 05:41 PM
BinaryJay
05-07-11 08:40 PM
Quick Reply: how to change the radio light
