original oem wheel hubcaps
I have I've tried them everyway some 2 of then went on easy but you can hear them move when ur driving on bumpy roads and 2 of the other ones are on tight and make no noise
For those, a rubber mallet works quite well in my experience lol. The chattering is from them not seated properly. You can attribute that to weather fluctuation since hot/cold expands and shrinks plastic pieces pretty well. To remove the chatter, put some foam between the wheel and the caps.
JUSROLLIN
10-02-03 01:28 PM
