engine problems? lexus es 300 96'
Old 01-02-11, 11:06 AM
IcePrince
IcePrince's Avatar
Default engine problems? lexus es 300 96'
Hi I was wondering if some of you guys can help me. Okay so my motor won't turn on. When I turn the keys the engine does not ignite... instead I get a rapid clicking noise. Everything works as far as electricity and such, but the motor is not. There is also a half a tank of gas in the car as well. Thanks.
The car is a lexus es 300 96' by the way.
Old 01-02-11, 11:08 AM
Ice350
Ice350's Avatar
Sounds like the starter needs to be changed.
Old 01-02-11, 11:13 AM
PFB
PFB's Avatar
If all you get are clicks when you try to start the car, than check in the following likely order.
a) Weak battery.
b) Loose/Corroded Battery Cable
c) Loose/Corroded Starter Cable.
d) Defective Starter (Least Likely)
Phil
Old 01-02-11, 11:22 AM
IcePrince
IcePrince's Avatar
oh thanks do you know how much would it cost to replace the starter.
Old 01-02-11, 03:05 PM
88Legend
88Legend's Avatar
Use a multi meter to check the charge of the battery. Full charge is 12.7v.
When a battery is weak, you will hear the rapid clicks because the starter is trying to engage but doesn't have enough power to.
I bet it is just a dead battery.
Old 01-02-11, 03:28 PM
marcoes300
marcoes300's Avatar
if it doe ''tik tik tik '' when you try to start your car .... its probably the battery ( happened to me ) just try to recharge or boost the batterie ....
Old 01-02-11, 04:33 PM
WAES300
WAES300's Avatar
Doesn't sound like an engine problem. Try jumping it first, I bet it's just a weak battery..
Old 01-03-11, 07:50 PM
lexuskid16
lexuskid16's Avatar
This happened to be before, my battery was weak.. But after I got a new one (OEM) it was all good. But, maybe you should just get a recharge and that should do it.
Old 01-04-11, 12:44 PM
rcpeters
rcpeters's Avatar
Default Dead or Weak Battery
Yep, the same happened to me last month in my ES300. New battery and it started right up.
LexusGuy79
Performance & Maintenance
09-28-18 04:56 PM
VladSoare
Hybrid Technology
12-31-15 05:13 AM
DavidPil
10-16-13 07:23 PM
sneakers
03-18-12 10:31 PM
Patsum
03-03-12 01:46 PM
Quick Reply: engine problems? lexus es 300 96'
