Aim down HID's on a '95ES?
I bought DDM 35w 4500k raptor HIDs. Installed them and they look great!!! I have heard, however, that i should aim them down a bit since the housing isnt made for HIDs so they may blind oncoming drivers... is this true?
I will try to turn my lights on, and drive my wifes car past mine, to see what it looks like, but we are on different schedules and i havent had the chance to do this, so in the meantime would appreciate the advice from you guys. thanks.
Since you have Hids on them, you won't have no problems because of the projectors. Unlike other cars that have no projectors, they glare everywhere and blind oncoming traffic. Other wise, your fine man!
I would find a nice flat wall and double check your alignment, Halogen projectors will still glare, maybe not as bad as reflector housings, but they still weren't made for HIDs.....
Halogen projectors are made to project lower lumin halogen light vs. the HID projectors which are created to project a higher lumin HID light with a more distinct beam pattern and cut off shield (to prevent blinding on coming cars).
I have 6000k from DDM and readjusted them, I don't have any cats or birds so I figured there was no sense in lighting up tree tops....
One day I'll take mine apart and play with the lens distance to see if I can get a better cut-off line, but it probably won't be tonight...or even tomorrow....
You probably have something like this with your setup noe...
![](http://i27.tinypic.com/2uembe1.jpg)
As you can see the blue "bleeding out from all over is what people actually see as "glare" that oncoming traffic sees.
These are pics from HID projectors and what thier cut off should look like...
![](http://www.hidparts.com/info/wp-content/uploads/2010/02/MDXPrismaLenscutoffWire.jpg)
![](http://s51.radikal.ru/i134/0902/dd/3d81d606ac5c.jpg)
Here's some decent info I found by googling for a second or two.....
http://www.honda-tech.com/showthread.php?t=418823
Adjust them anyway. Glare is glare. I would feel pretty guilty if I knew that by lowering a few degrees, I could lower the glare a bit. Just do it right and then leave it. The cutoff for our cars are pretty decent for the age. This is what you should expect to see when done correctly...
Keep in mind that I took my headlights apart and cleaned up the dust on the projector bulb itself to help further cut down the glare. Hence why my cutoff is quite sharp
![](http://i28.photobucket.com/albums/c201/reboot870/HID/IMG_2651.jpg)
I have to agree, the cutoff is pretty decent in my ES, I really want to take apart my lights (ones fogging anyway so I'd like to reseal it) and try playing with the lens to get it even sharper...
you should always aim it, projectors are useless if not, might as well be reflective. cutoff should be visible to prevent blinding of other drivers, front or back.
by the way, ddm is not garbage at all.
The light above our cutoffs isn't even glare, some guys just bash on lights just because it aint sharp enough, wide enough, or does not have color LOL.
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs316.snc3/28466_398988042034_621582034_4844506_7721048_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs130.snc4/36868_398989372034_621582034_4844559_5155629_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs150.snc4/36868_398989377034_621582034_4844560_6229343_n.jpg)
I am very happy with my $40 DDM's. Even if the $400 HID's are better quality, IMO the law of diminishing returns is greatly in effect. There is no way that $400 HID's are 10 times better than the $40 DDM's.
You could have at least backed up your claim with a story from personal experience.
I didn't realize you guys get butt hurt when I bashed on your cheap DDM lights.. I say it's garbage because the hid quality is the same as a regular halogen bulb! But hey, everyone has there opinion on the brand, so whatever. And the hid kits I buy are actually German engineered made, same company that makes hids for Audi, Mercedes, BMW, etc. So don't try bashing on me. Like I tell everyone, don't half *** on your cars and buy cheap **** and just do everything the right way!
Just because you buy high end stuff doesn't give you the right to bash others correct? That is my main point. Everyone is entitled to their own opinion as DaveGS4 likes to say, but your opinion had ZERO functional input in this thread other than starting something. Reported for being just plain unreasonable
Oh you guys are right, my bad if I came in here telling you it's garbage. And this is a forum, everyone has a right to speak there freely opinions. But I guess this forum works differently.
