Engine goes to idle RPM after revving to 3000
Old 01-24-11, 09:47 AM
sherwoodjb
sherwoodjb's Avatar
Question Engine goes to idle RPM after revving to 3000
Hey guys, new to the forum here, hoping to get some help?
Yesterday I changed fitlers...an hour later I turned on the car and it would immediately die after starting.
I took it apart and cleaned everything (throttle, MAF...) with the carbon cleaner....now it'll turn on but when I rev the engine past 3000 it goes immediately back to idle.
I haven't tried to drive it yet but I'm not sure what the problem could be.
Any help would be extremely appreciated.
Old 01-24-11, 10:02 AM
sherwoodjb
sherwoodjb's Avatar
By the way, this is a 2004 ES330 with 58k miles
Old 01-26-11, 07:43 PM
DRACO A5OG
DRACO A5OG's Avatar
Are you pulling any CEL codes?
Sounds like when you clean the TB, it may have left some gunk around the flap causing the TPS to get a false reading.
Get a helper to press the accelerator pedal all the way down and make certain there is no slack or too tight at the throttle body cable connection. If slack/looseness, adjust until it is within spec.
If this does not fix it your TPS ( Throttle Position Sensor maybe defective ), hope not.
philllyj
Performance & Maintenance
18
04-05-23 07:51 AM
mikesb7
08-05-19 05:15 AM
Gate
Maintenance
10-02-11 12:27 AM
aerosmith1
GS - 1st Gen (1993-1997)
04-18-10 01:34 PM
Mikes94GS3
12-09-07 11:21 AM
Quick Reply: Engine goes to idle RPM after revving to 3000
