ES330 TRD fitment?
Do the following TRD parts fit a 2004 ES330?
TRD rear sway bar for 2002-2006 Camry/2004-2009 Solara (PTR02-06041-01)
TRD strut brace for 2002-2006 Camry/2004-2008 Solara (PTR06-06041-01)
TRD lowering springs for 2004-2011 Camry/2004-2011 Solara (PTR07-06040-19)
TRD oil filter for 1988-2005 Camry (PTR43-00080)
TRD air filter for 2002-2006 Camry/2004-2008 Solara (PTR43-00087)
TRD front brake pads for 2004-2008 Solara (PTR09-35086)
Is any modification needed in order to fit? Are there other OEM Lexus or Toyota upgrade parts like this that I have not listed?
also the springs and brake pads wont fit...ES has different suspension and brakes...the ES has a dual piston front caliper setup, solara and camry have 1 piston.
Thanks, picked up the ES two days ago and was wondering what could be done to it. Did you notice any performance gains with the air filter? I know they will only be minor gains, just wondering.
Are there any L-tuned or F Sport options for the ES330?
I suspect the TRD strut bar is a bit stiffer, but the stock one is pretty nice, I suspect you won't see any difference. I am looking into the rear sway bar, would look cool if nothing else. There are zero L-Tuned or F-Sport options for the ES. I've never actually seen pics of the Camry/Solara exhaust on the ES but all the research I've done says it will fit fine. The hangers are in the right position and all, only problem might be the tip does'nt line up on the rear skirt perfectly. Also, I've only seen negative reviews for the drop-in air filter so I have'nt wasted my time/$$ with it. Thanks!
The TRD PTR02-06041-01 rear sway bar fit perfectly in my 2004 ES330 and made for a flatter and tighter ride. Replaced stock front sway bar with a bar fabricated by Carolina Swaybar. Definitely more responsive and still less roll.
delta901
09-23-08 12:29 AM
