how to remove fender on 98 es
hi ! i wonder if someone know how to remove the fender !? is it complicated or its easy to do ( i know that it can be long to remove but how hard i have no idea )
tanks for your help !
marc
* for a 98 es300
marc
* for a 98 es300
ther should be screws along the top and i think like 2 screws near the headlight that connect it to the bumper.. i think its either a 10 or 12mm socket.
i havent needed to remove mine.
If you do a YouTube search you will find several videos on how to remove a fender in general.
I did not find any that are specific to a Lexus, but the steps should be similar, and at least will give you an idea
Here is an example of a video I found that may help you out a bit.
http://www.youtube.com/watch?v=eZT_S4XtS9k
These are the instructions as detailed in my Haynes Repair Manual.
So basically, there are fasteners/bolts underneath the front bumper/fenderwell, all the bolts, screws, and clips inside of the fenderwell/fender liner, 2 bolts in the door jamb, and 3 bolts along the top of the fender. It may vary slightly since the manual is (mostly) for a 97-01 Toyota Camry that shares the same chassis.
1. Raise the vehicle, support it securely on jackstands and remove the front wheel.
2. Remove the front parking/turn signal light.
3. Detach the inner fenderwell screws and clips, then remove the inner fenderwell and mud shield.
4. Open the front door, and remove the upper fender-to-body bolt.
5. Remove the lower fender-to-body bolt.
6. Remove the remaining fender mounting bolts.
7. Lift off the fender. It's a good idea to have an assistant support the fender while it's being moved away from the vehicle to prevent damage to the surrounding body panels.
8. Installation is the reverse of removal. Check the alignment of the fender to the hood and front edge of the door before final tightening of fender fasteners.
tanks all for your help ! i will make a step by step guide
now i need to buy the inner fender and the black thing at the doors bottom... but i didnt find those parts
marcoes300
03-16-11 05:25 PM
