2005 ES330 Vanity Light Help!!!
Iam putting a led light in the vanity part of my car everytime i turn it on it blows the fuse under the steering wheel and i check it a 7.5 fuse and then i replace it for the same on and it blows as well can you but fuse on the dome higher than a 7.5? I Need Help??
Yoiu have a short circuit, or a defective LED bulb. Put back the original bulb and see what happens?
Your problem is likely located in the area that you were working on. You need to find the cause and fix it properly.
Whatever you do, DO NOT REPLACE BY A BIGGER SIZE FUSE. You will be creating a fire hazard.
biacs
07-17-15 07:46 AM
