COMIN SOON 97es3
COMIN SOON 97es3
so for a about a year now i've been debating on grabbing suspension, but which setup. i was going to go tanabe df210s from the beginning but decided to just drop all the money at once and grab coils. deciding to go with som BC coils.
Not only that, but changing just the springs is a good way to mess up the research and development that Toyota put into the set up for the car. Either change the whole set or don't touch it I say.
I'm limited by the frame of my Camry. It protrudes 2in lower than any body panel for some reason. My BC Racing coils don't seem to have much of a limitation since I can go beyond slammed (body sits lower than wheels if I must). I do believe some brands do though. You'll probably have to email the manufacturers you are thinking about buying from.
I track at times. Sides, you can drive about being that low and being static
6/4 should be the MINIMUM you get. If you plan on upgrading spring rates, the general rule to follow is +/- 2. So in my case, since my coils came with 6/4, I'd upgrade to 8/6. If you want to go more, you'll have to upgrade some components on the coilovers itself
Can't wait to see it, been thinking of trading these springs and shocks out for coilovers. Been fun with the lower stance, but Christ all mighty it's a rough ride and not the most optimal handling I must say.
