Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
- Lexus IS GS: How to Replace Oxygen Sensor
Step by step instructions for do-it-yourself repairs
bad oxygen sensor, can i ignore it?
Please make sure that if your car has AFR sensor (air fuel ratio) then you replace it with an AFR and if you have oxygen sensor then r,eplace it with oxygen sensor since signal detection circuitry inside the ECM looks for a specific voltage range for feedback signal. If the feedback signals are different then ECM will throw cel light and could also lead to damaging the ECM. Thanks
techiedude
05-02-12 06:57 PM
dcapo
08-02-11 03:30 PM
