Air Bag Light Flashing
Got a question for the experts or the ones who have experienced this themselves. I did do some research on here and found some good info, but my situation is weird. So, I thought I would ask on here. I have a 98 ES300 with about 155,000 miles on it and just the other day I noticed the air bag light was flashing. I read the advice on here and took it to the Lexus dealer and my friend that works there, had them scan for a code and to my surprise, there was no code. The tech even drove my car for awhile and the indicator light did not flash. I picked up my car on President's day and was told to bring it in when the light stays on. Well, when I got home, 8 mile drive from the dealer, I decided to wash the car. When I finished, I looked into the car and noticed the air bag light was on. It was not on when I got home, it turned on while washing the car. I then started the car and the light stayed on and as soon as I put in into drive the light went off. I placed back in park and the light went on, put back in drive and turned off. I then drove about 20 minutes, 14 miles and then placed it in park and the light never came back on. I then drove back home on the freeway and light would blink occasionally, but now the light stays off. I'm wondering if there is a lose wire or a wire that got wet when I washed my car. Any suggestions or ideas. Thanks for the input.
That's a weird problem, but it does sound like a flaky connection. I do know on these systems that the ECU will flag a problem if the airbag light indicator itself (or the associated circuit) is bad, that might be what's going on with your car.
What throws me off is the light is not always on or flashing, bad ECU?
You could try cleaning the connector to the airbag control unit. Radio shack has a contact cleaner called De-ox, comes in a small spray can. Make sure that you disconnect the grd cable on the battery, and wait at least 5 min before removing any of these connectors.
Where is the air bag control unit located? Im wondering if one of the wires going to the bumper sensor is causing this issue. Just weird that it came on while washing my car. Wondering if water got into the sensor or a wire that is exposed and water got in. Thanks George and Lexus2000 for your input.
From the service manual, hopefully it will help you out.
http://img818.imageshack.us/img818/9...rbagsystem.png
Update: The air bag icon continues to flash, but now seems to stay on more and is even on when the car off. From my observation, it seems to be a bad sensor or something thats senses motion. For instance, if im at a stop light, the icon will be on and as soon as I accelerate if goes off, but comes on again when I drive at a constant speed. If I hit the brakes it will turn off, but then come back on at a stop light. Im probably going to take it back to the dealer and have them scan for a code. The first time I took it to them, it barely flashed and was not on when I took it to them and when they scanned it, no code. Im hoping now, with it more on than off, it will have a code as to what is wrong with it.
Update on my issue for those that it may help out in the future.
Well, I took my car back into the Lexus Dealer about two weeks ago. I have a good friend that is a service Rep. at my local Lexus dealer and she really takes care of me with service and cost. Anyways, took it back because the airbag light is back on and stays on. Well, the tech had narrowed it down to either the airbag unit or the wire loom to the engine compartment. He scanned for a code and no code came up, so he was leaning towards a problem with the wire loom. The other day I got an update and low and behold it's the wire loom/data link cable that runs out to the front of the car in the engine compartment. Apparently, this data link cable is old school, obselete in a sense to Lexus. This was the old school way of reading codes from the airbag unit, but apparently Lexus can now plug into the unit via another cable link behind the glove box which actually gives the Lexus tech a trouble code on a scanner. Well, the old school cable in the engine compartment is apparently frayed somewhere and is ground, causing the airbag light to flash and pretty much stay on. He came to this conclusion when him and another tech were working on it and one tech moved the wire cable and the other tech noticed the airbag light turn off, when he pulled the wire back it came back on. Conclusion, the tech suggested, since the data cable is obselete, he suggested to uplug if from the other cable link behind the glove box. The other choices I had was to place that old school data link cable or have them run new wire to the the other end of the cable in the engine compartment. I opted to have them disconnect the old school cable, easier to do and cost effective. They have assured me the SRS system is properly working. I hope this may help others in the future with maybe the same issue. I have to admit this issue was very unique, even the tech had never experienced this before on another ES300. Oh well, just my luck.
I have a '99 Lexus RX300 with 180K miles. While driving the car on the freeway today for several hours, the air bag light began flashing on/off at about a 1 second rate. This flashing duration became more random until I stopped for gas about 30 minutes later. When I restarted the car, the light was out, and remained out for over 3 hours. Just before I stopped again for gas, the light began flashing. Restarting the car and driving another 2 hours and the light stayed out.
Reading through the thread, it sounds as though a wire in the engine compartment may be the issue. Since the thread is 5 years old, is there any new information which can be shared from the talented masses?
Hi, I have a 1999 lexus rx 300 and let airbag light start flashing. My car have a 235,000 miles on it. Any suggestions that I follow to trouble shoot this or should take it to the dealer.
Thanks
Thanks
