Need Help Replacing Door Lock Actuators
I have a 2003 ES 300 and two of the door locks no longer respond. I'm told that this is quite common in Lexus (and Toyota) and that I need an entire kit, not just a simple part to be replaced inside the door. It is the front passenger door and the rear driver side door that are being problematic. Does anyone know the part numbers I should be looking for and how tricky these will be to replace? Your responses will be very appreciated.
im having a issues where my driver door locks from the inside and stays locked. i can lock it from outside the car but if when i lift the door handle to open the door from outside it always unlocks. if i hold the lock button in the locked position and try to open the door again from the outside i hear a clink or clunk. i took the door apart and all the rods are in place. im trying to find out how hard it is to take the door handle apart or the lock latch thing that holds on to the door
gulleyman
GS - 1st Gen (1993-1997)
15
09-19-21 08:05 PM
magneticrt
RX - 1st Gen (1999-2003)
07-07-14 05:36 PM
