where is the cabin air filter is located ??
hi , i would like to know where is the cabin air filter is located ??
and where is the air filter for motor ( never cheked yet :S )
tanks
tanks
I installed the TYC, which is cheaper, but as I didn't like its charcoal smell, I decided to order a Denso from Rockauto. Much to my surprise, when I removed the TYC and compared it to the Denso one, I realized that they were 100% identical, (cheap plastic frame, fragile filter element, colors, no brand imprint, and of course the same smell) that is, both TYC and Denso have the same cabin filter supplier...
^^ That's interesting, I picked up a Denso filter awhile back, and it's not like that. No smell and was the same as the original (never changed) I took out. I wonder what gives.
This whole cabin air filter thing is interesting. Does it make a tangible difference in air quality to replace them?
I'm looking at mine tomorrow, but I am afraid to pull mine out as I know they haven't been changes in the 16 years the car has been around.
https://www.clublexus.com/forums/es3...e-97-01-a.html
The plastic frame is solid grey, the filter element is thick, sturdy and looks well designed to trap all dust and particles. My aftermarket Denso has a dark green frame and the element (light brown) is made of thin paper with black charcoal stains on it. Definitely looks cheap.
Maybe your car does not have a cabin filter. Otherwise it would smell really bad after all these years.
I had a Denso and but (2) aftermarket for $11 each. You can see in the link below that the OP and Lexask8 is two different filter. The OP's filter is better (which is the case I am in).
