Did they ever fix the 2002 ES300 Transmission issues?
Just wondering if they ever fixed the 2002 ES300 transmission issues I hear so much about? Also is there any other issues that have come up with the majority of the 2002 ES300 models?
Also were any of these recalled for the unintended acceleration issues?
Edit: Holy S***: http://www.arfc.org/complaints/2002/.../10313640.aspx
Guess they didn't, any of you experience the same issues?
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
A clue to the cause of that complaint can be found near the beginning, where it states: "My wife ....."
(Many times this is also explained as a PEBSWAS trouble - Problem Exists Between Steering Wheel And Seat).
Did you ever take a look at the other complaints?
http://www.arfc.org/complaints/2002/...00/?q=&page=10
There is like 40 complaints and 20 of them are before 07 when the court issues started to slowly come together. Can we just ignore all of them?
I thought you were only pointing to that one, first complaint.
But, FWIW, I owned a 2002 ES for 5 years and had only one major complaint - the hesitation when accelerating from a slow roll (leaving a gas station, merging into traffic from an approach ramp, etc.)
Lexus never fixed that for me. They reset cpu; explained that the car was learning my driving habits; etc. They did everything except fix it. It is the sole reason I finally got rid of the car. It was downright embarrassing when driving with others, and explaining that Lexus says it's "normal".
I've never experienced sudden or unexplained acceleration at any time during my 4 years with the car. The hesitation problem, however, was a serious safety issue as far as I was concerned, and after giving the car 5 full years to "learn" my driving habits, well that was more than enough time.
Lexus dropped the ball on that issue, by never admitting that they had a problem with their "drive-by-wire" system.
I was happy to get out of that car ........ I don't miss it at all.
Yup, I have a '98 also - bought it new in Oct '97.
I absolutely love that car ! It's actually fun to drive. (and it never had to "learn" my driving habits ...... )
Walt
In Soviet Russia, car learns you.
Honestly, the whole "wait until the car learns how you drive" is one of the most pathetic things I've ever heard. The car should simply respond to how you drive, instantly. Not have to learn and improve how it responds over time. You're driving a car, not riding a horse.
FWIW...
I'm disappointed in the tranny in my '05, there is no excuse for this behavior on a car like this. I'm not sorry I bought the car, I still really like it. But I do miss my '98, it was more fun to drive. If you went into Lexus to complain, I doubt you'd get anywhere, good luck with that. They may admit to the poor behavior, but the car is too old now to get anything done for free. I really think the issue could only be fixed with a totally new, different transmission. That's not gonna happen.
OTOH, I spent the last 4 days driving my Mom's '07, total night and day difference. Absolutely none of that crappy flare in the 1-2 and 2-3 shift, very solid. I did try really hard at one point to get it to do the weird lunge thing from a slow roll, and I could barely feel it happening.
Bottom line: if you know of someone considering an ES, tell them to stick with a pre-02, or save up more money and get an '07+. Avoid this generation.
If you know of someone considering an ES, tell them to stick with a pre-02, or save up more money and get an '07+
Yup, I agree. The 05' tranny sucks. I am probably going to get rid of the car due to this problem. Otherwise, probably a nice car.
"the car has to 'learn' how you drive" ??? Gotta be kidding me. And I've tried the disconnecting the battery thing........no difference.
Well, I alsmost T-bone twice during the left turn a few years back. If you have the tranny problem, you would understand what I said.
I am in the process to fix 05 tranny by making ATF a bit thicker so that the digital IC's would read the pressure in side tranny a bit more accurate. To do that, I added a bottle of Lucas tran fix and reset ecu by removing battery for a few minutes.
From my personal knowledge in engineering background, I don't think it is a software issue with the intermittent delay/lag about 0.5s to 1s. For those who don't have this problem, one second would not make a big different. But, it is a live and dead the make a left turn or merge into traffics or cost a few hundred during a stop and go on belt way.
Here what I think: when you step on the gas, the electronics circuits read the pressure in side tranny wrt temp, current state and other avariables. If the ATF a bit thin, then it reads a bit off, which mean a bit delay/lag.
I am NOT a fan of Lucas tran fix/products, but it would NOT damaged your tranny either. Give it a try and post our results.
Hey ToLex168,
I was just curious if your attempt to add the Lucas trans fix helped out with the transmission hesitation problem ?
If I decide to keep the car, I am due for a complete fluid change (tranny, differential, etc.) and would probably attempt your suggestion if you think it is a difference maker. I just put in Castrol Synthetic Edge for the engine oil change and will replace the timing belt, water pump, bushings/pulleys, serpentine belt, etc. in the very near future if I end up keeping it.
Really is too bad about the hesitation issue as it seems like a pretty damn car otherwise.
