1999 ES300 Rear Rotor Frozen
My rotor on my 99 ES300 is stuck and won't come off. There is a rust ridge on the inside of the rotor and the emergency pads want to come with it when I try to slide it off. I want to be careful and not cause offer issues. Where is the emergency brake adjustment on a ES300? Do you need a special tool to make the adjustment? If I can adjust them in, then I can get the rotor off.
There is a rubber plug in the disc, remove it. Then rotate the disc so the hole is at it's lowest point. You can then rotate the adjuster to back off the e-brake shoes to allow removal.
The correct procedure to re-adjust the e-brake clearance is to turn the adjuster until the rotor locks, then back it off 6-8 clicks.
![](http://img190.imageshack.us/img190/6772/discremoval.png)
Will not fix a dragging caliper, the adjustment is only for the parking brake.
Thin screwdriver works.
99custom
02-25-18 07:55 AM
