tail light problem
ok this is the problem , i have a 99 es300 and this only happens when i turn on the lights and press the breaks , the tail light picture on the dash comes on and when i let the breaks go the light goes away , but it only happens when u turn the lights on , when u press the breaks in the day when u dont have the lights on the the tail light picture does not come on, checked the tail lights and none of them is out
Loose connection with the bulb in any of the lights. Take each one and clean each contact point with rubbing alcohol and put it back in. Should take care of the problem assuming the lights are 100% working and not doing the half brightness thing that some lights have
Just ignore it. This is a common issue.
ONe suggested fix was to take ALL of the bulbs and buy matching ones - all from one company since they're made in one way. Not mixing and matching.
I've had this light on for about 3 yrs now. Sometimes it goes on, other times it doesn't. Meh.
