01 es300 Randomly car won't stay running after starting!
Hey guys, I am having two issues with my car. This doesn't happen a lot but it happens in cold and warm weather. My car will crank over and RPMs will rev up to about 2500 then the engine will stall and the car will shut off. The only way for me to get the car started when this happens is to hold the gas peddle down and turn the engine over and keep the RPMs above 3500 for like 5-10 seconds and while that is happening it is running very rough and weak. After that it will start to idle smooth like it normally does and then everything works fine. Other times when I turn it over it will just be cranking and won't start but normally when that happens I just turn the key back and then try again and it starts up, it doesn't have a strong start when this happens but it is nothing compared to my first problem. I would assume both of these problems are related. My guess would be a senor or maybe fuel pump. Anyone got any suggestions on what to try first?
My brother is going to clean my IACV tomorrow. I will let you know what happens, although this particular problem can not be re created in any way it's completely random so I probably wont know for sure if it fixes the issue right away. Thanks for the reply's guys!
Okay so my brother cleaned my IACV out and he ran some stuff through my fuel system and clean the injectors out and I drove the car all day and turn it off and back on a lot throughout the day and everything seems smooth idles better, better response from the throttle and best of all it started every time no problems! Hope my problems are solved thanks for the suggestions guys!
ooh mann now i have got the same problem...it happen only sometimes..so with IACV cleaning it cleared? do u still have any problem? also do u know why the IACV become dirty? and also how much does it cost?
Had the same issue a few months ago as well. I was told to replace the IACV. Not being a DIY guys, I paid $330 (parts and labor) to get the deed done. Probably not a good deal, but time and convenience were more important for me and I didn't want to do something temporary that would require me to address it a few months later. Car runs great once again.
Sorry for the late reply. I rarely log into the email that CL is attached to.
Hmm...not sure if it is OEM. I went to this Vietnamese shop that gets really good Yelp reviews. The owner there just quotes stuff off the top of his head and I think it was $230 for the part and $100 for the labor. There's a sketchy feel to it because of that, but it didn't seem unreasonable and I can drive in w/o an appt and get seen pretty quick.
He does a lot of Asian makes and I did observe genuine OEM parts being delivered to his store while I was waiting, so I figure he used decent parts.
I recently found a former mechanic who has a full set up in his home garage and does work on the weekends. I'll probably go with him for my maintenance in the future since I just buy the parts from Autozone and can watch him work and get to know my car a little bit more.
winner155
24
02-15-12 05:13 PM
Dalenkwint
07-06-05 04:40 PM
