Coolant leak
Most likely it's the water pump.Check all hoses (coolant related) for any leaks. My es is actually in the shop write now getting the water pump and timing belt changed because the same thing was happening to mines. You can get an OEM Aisin Timing belt kit with water pump included for $129+shipping on www.rockauto.com. Move fast or else you will eventually overheat your motor and blow your head gasket.
