ES300 Clock Wiring Harness / 12v Constant
I have had no luck with a response for this in the past but I'm still trying anyway. What I need to know is where to tap 12v constant from with a very very low draw. All I'm trying to do is bypass my factory amplifier since it's blown and I don't want to spend the money to replace it. There are 4 wires that run into the clock and I know at least one of them has to be 12v constant since it keeps the time on the clock.
My other option I was considering was highjacking from the CD changer, but I don't want to pull that out just to figure out which wire to use. Any advance help anyone could provide would be great. I just need it to hold my presets since I'm trying to reinstall my factory radio.
If I understand you correctly, you are looking for a 12V constant wire/source and do not know which of the 4 wires going into the clock is the one, or you have identified another possible source and want someone to tell you which color wire to use?
Save time and just do a test. If you have a multimeter, set it to the lowest voltage scale, touch the red lead to the wire and the black to ground. Or, use a 12V bulb with 2 wires. Either way, you'll find the 12V you need...or am I misreading your post...
saltyreefs
04-19-06 10:28 PM
DroppedGS
12-09-05 04:55 PM
