LED fast blinker...
LED fast blinker...
i had LED for turn signal for sometime but never put it on until yesterday.so after putting on it started to blink fast so i searched and i got like need a ressitors or a relay . I have noticed that the LED bulb works fine on;y when i press the hazard switch on , but blinks fast when i turn left or right signals..weird. i m lost and i couldnt find like a good DIY with pics. Also can i get those things from like canadian tire store or something? thanks
u mean flasher relay? if so then how would i choose the right one. Also is it true that any flasher will fit a car?
Flashers are usually specific to makes or sometimes models of cars. They have a certain pin setup that plugs into a harness. You can find LED flashers that have a lower voltage so it flashes normally. The stock flasher is made for incandescent bulbs that run at a higher voltage; LED bulbs are low voltage so the car thinks that a bulb is out.
I tried going to O'Reilleys/Autozone to ask for a LED signal flasher, and they just stared at me with an empty look...
I had the same problem with my 94 ES.
Threw in that EP-35 and it worked fine.
The 2nd Gen and 3rd Gen use the same relay i found out
after doing some research on here and testing it.
Search some of my threads and you'll see a post where a
member on here was kind enough to help me and post pics
of the relay he used on his 3rd Gen.
