definative transmission problems. what are my options
ok update to my last post about my tranny problems. when i start and the engine is cold it wont shift into 3rd for 5-10 seconds and runs in the 3k+ rpm range but once it shifts into third it shifts in an out just fine till it sits and cools off of course. 4th gear is a bit different no slipping when its in that gear but occasionally when it up shifts from 3rd to 4th it will do so slowly and then rpms will not fall fast or evenly(they will drop about half what that should and remain there for usually 1/4 to 1/2 a second and then drop to where they should be.) but thats some what rare. so today i had the codes read and this is what i got:
p0770 and p0773
p0770= shift solenoid "E" malfunction- SSV DSL
possible causes: shift solenoid stuck open, blocked oil passage, lockup clutch failure
p0773= shift solenoid "E" electrical malfunction- SSV DSL
possible causes: open or short circuit condition, poor electrical condition, failed SSV DSL
so what does all that mean? does it mean a complete rebuild or can that problem just itself be fixed? if it isnt fixed soon what are the most likely outcomes? can i get away with it for awhile?
p0770 and p0773
rickyp39
11-05-10 12:18 PM
