How Do I?
I removed my backseat in my 95 really easily. In the 95 all you have to do is take a flat head screwdriver and pop it out. Just stick in the screwdriver and use it to lift up the seat at the pressure points, and it should pop right out. There are two points, one on each side, a few inches from the side. You can find them easily because there is more pressure in two points when you try to lift up the bottom. I imagine it is the same on the 92 as the 95. It is the same as Mustangs, some chevys, and probably others. If I remember correctly, you will just need to unbolt the back of the seat. In my 95 it is bolted in, but I don't recall where the bolts are. Hope it helps.
