Have some questions about some HIDs
Do your headlights look like either of these?
HALOGEN:
![](http://www.autoparts101.com/wp-content/uploads/2011/02/2001-Lexus-ES-350-Black-front-view.jpg)
HID:
![](http://img256.imageshack.us/img256/5997/38845356.jpg)
What you need is an hid kit; either slim or regular ballast [i prefer regular, since slims can be a hit or miss], the bulb is either an H7 [halogen], or D2S [Oem hid].
I think that they are halogens look at the pics i uploaded below
My preferred seller
***no need for a relay harness**
Here's an install: *scroll down* https://www.clublexus.com/forums/es3...imeline-3.html
GL!
HALOGEN:
HID:
My preferred seller
GL!
And this is my Baby Below
Those are halogen, you DO NOT have the HID housings.
Furthermore, I don't recommend you just stick an HID kit in there. Here's why:
If you do however do it, aim them low, use between 4300k to 6000k, and use 35w ballasts. You can use a relay harness if you want, but you probably don't need to. People use them because they are afraid of frying their stock halogen wiring. Try it for a week or two and check for flickering lights when igniting and heating up. If not then you can probably avoid a relay harness, but if theres flickering then you should consider a relay harness. Nice car btw. Good luck.
- Illegal
- May not pass inspection
- Glare and overly bright for other drivers
- Possibility of getting ticketed
- Illegal
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
So i dnt need the relay?? cuz people have told me that there bulb housing melted because they didnt have the relay harness! and i need hids on the lowbeams not the highbeams??? and nice lex by the way
^^ absolutely not. What you see above is 3 years encounting on the low beams [bd pic but those are 4300k] and this summer on the fogs [6000k to make nice contrast] ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Those people that told you that are uninformed, or they were running some 'high power HID bulbs' [generic blue bulbs] off eBay which run super hot [stock is 55W these are 100W units]. They were sold a 55W HID kit [which will run hotter than the 35W obviously] or they had a ****ty HID kit...
^^^^^ Okay thanks for the info. ima get 4300k or 5k idk witch yet but do you think if i was to get eyelids for it that it would cut off some of the light so that it doesnt blind everyone else??? and what brand are yours?
I've been told the SAME thing from people who have HID's and even some of the local places HIGHLY recommend the relay for SAFETY reasons--"proper voltage, etc.. If this is the case, I've been waiting to purchase some 5k or 6k [brightest possible] bulbs for my 2ES. [Gathering info]
Muti007
GX - 1st Gen (2003-2009)
23
03-22-12 03:39 PM
