!! Need Help!! Low Rpm! no power!
waz up everybody?i need help! yesterday i went to school in the morning with no problems at all. when i got out of school, i turned on my car,(2es), i noticed that the rpm is lower than the normal.also the car was shaking. so i went home like this and when i accelerate it seems it have no power and it shakes alot. also when put in (r) it does the same and shake. does anybody now what could it be?? im thinking a oxygen senor or something like that.??!
Is the check engine light on? I'm no mechanic but the first things that come to my mind are:
-IACV needs cleaning
-MAF sensor needs cleaning
-Throttle body needs cleaning
-PCV valve is clogged
-Need new air filter
-Failing o2 sensor
What year ES do you have and how many miles are on your car?
-Failing o2 sensor
-Failing o2 sensor
-Failing o2 sensor
also they told me it can be a tuned up. i havent done a tune up since last year april and the who knows when the previous owner did one!
I would definitely get an experienced mechanic's opinion because the car may need a good tune-up if you're unsure about it's service history. You may want to try searching the VIN on Lexus.com to see if the car was ever serviced at the dealership.. Just to give you an idea of what you're up against in case you're thinking about doing it yourself.. check out the attached image of the Air Intake Chamber Assembly + Intake Manifold Assembly + sensors etc. (Note: this is the 97-01 ES300 layout)
If you are going to attempt it yourself just make sure you understand that you may be dealing with sensitive electronic components and to handle them carefully... Some of the other members may be able to help you out too.. good luck brother
LEXSGSTAR
03-02-09 01:41 AM
Bradster
03-31-03 05:24 AM
