New Hid lights and License plate lights
I try that once, i put the HID in the stock housing on my XB and went out at night, it looked bright and nice i could see everything, but the glare was too much and when i pulled up behind somebody it looked as if i had my high beams on, so i turned around came back home and took them off, and thats why i decided to do a projector retrofit.
You can go and use them in your stock headlights which will look something like this, or might not look bad at all to you, but the reality is that stock headlight weren't meant to have HID in them, even if you point down the light all the way, you still will get that gorgeous glare
You can go like this in your stock headlights.
![](http://forum.e46fanatics.com/attachment.php?attachmentid=183505&d=1149951674)
Or you can go ahead and get your self a set of projectors and do your self a retrofit, and you get this clean pattern look.
![](http://farm6.static.flickr.com/5185/5632607229_f4e8596805.jpg)
So if we wanted to take the plunge and go retrofit--2ES in my case--where do we start (for info, links, reliable stores/outlets, etc.)??
I'm already using, 6k's--I'm sure they sent me 8k's..[too blue instead of "hint" of blue]. Noticeably brighter and greater visibility than the Silver Star Ultra's they replaced. But I know there is improvement(s) to be had with ret-fits.
I'm getting my beam fixed tomorrow, taillights & marker lights smoked. I'll post pictures when its done. Next week im getting the yellow fog 3ks and the led lights put all thru out the inside. and Maybe some white rims but not sure what kind will look clean
Thats something i will never do again, specially to a lexus......But to each his own.
I remember i had tail light covers on my 280ZX and i was driving east while the sun was setting in the west, a cop was behind me and pulled me over because the sunlight was hitting the light covers and the RED when i was stopping was not 100% visible, so he gave me a choice to take them off or drive away with a ticket.........SIR YES SIR, took them right off
**** those taillights. and my taillights are sprayed its not wrapped or a cover so i dont get any glare from them. and when i get my yellow fogs put in next week hes going to fix the glare
