Help with installing second battery in trunk
what will i need to successfully do this? i already have a deka 9a31 under the hood, plan to get a deka 9a31 for the trunk. what will i need to successfully do this? i know i need to have an inline fuse, but what would be a sufficient fuse? to pull an amp draw from the back.....and do i need a battery isolator or anything like that? please help. thanks.
all you need to do is run power cable from the front battery to the back battery, thats it
. isolators are useless unless you plan on playing your system for long periods of time with the engine off. no need for a fuse between batteries, just before the amp.
Depends if you don't mind having a massive electrical fire if you get in an accident then sure skip the fuse. And if you don't mind not being able to start your car cuz you pumped music at the beach for 3 hours then you can skip the isolator.
Ok, sorry I wasn't familiar with AGM technology. Looks like a step better than gel. For either type I would recommend a Schottky isolator to reduce the charging voltage to the aux battery, unless maybe there is a 0.2-0.3 V drop in the cable to the trunk, could well be.
Tons of cars come from the factory with the battery in the trunk. Most BMWs are like this, the Mini Cooper, etc. Hell, my old VW had the battery under the driver's seat. That was... I think a '75?
To answer the fuse question...you need to start with a design...which is based on your design goals. There's two basic options. 1) Use an isolator and a small cable which is going to carry charging current only, in which case you can use small fuses. 2) No isolator, big cable, big fuses. Note that you need fuses on both ends of the interconnect cable.
Some BMWs have the battery under the back seat. I would think by now they would know a few things about quality engineering.
clp71220
07-22-17 05:22 AM
adreano17
12
07-01-11 09:34 AM
