need help with rear abs removal and install
so i damaged the rear abs senors i believe when i changed my springs and shocks install..does anyone know if there is a good write up on replacing the rear abs sensors??
No special tools. The issue you may have to deal with is the sensor itself may be seized in the hub, so you'll have to dig it out of there and then clean up the bore. I believe you have to take the back seat out to get to the connector but I'm not 100% certain on this. Either way, the job is not difficult at all.
Just wanted to post an update...I changed the abs sensors and my abs light and trac light are both gone..it was a pain to pull the old sensor out and I ended up busting it. I had to dig the rest of it out but finally got it..installed the used ones I got from craigslist for 35 bucks for a pair...gotta say I don't wanna do it again.
