Inaccurate/erratic speedometer 2000 lexus es300 - please help
I have posted 2 other threads on this topic, starting a new one since there seems to be more to my problem.
My speedometer will slowly creep up to around 60 mph, then stay "stuck" there until there is a significant reduction on speed. Then the needle will quickly jump down to the "correct" speed. My guess would also be that whenever I exceed 60 mph the needle simply stays and will not move until I actually hit 60 mph again. At that point the speedometer "catches up" with the correct speed again at around 30 mph.
This is what still works in my car:
- Odomoter works normal (on actual and trip A and B mileage)
- Cruise Control
At this point the problem (my guess) could be the vehicle speed sensor (VSS, still trying to find the location of it) or the instrument cluster itself. I have yet to check if the car shifts into 4th gear (I believe it does). I also want to note that a dealership 2 owners ago left a GPS tracker which is behind my coinbox. It is still wired in, active, with the light blinking. I wonder if this unit could be throwing my instrument cluster off?
ANY SUGGESTIONS/COMMENTS ARE GREATLY APPRECIATED!!!
- Cruise Control
MYSTERY SOLVED (a least for my case): I had the GPS tracker removed, no impact. Needle would still not move at any speed above 62. I took the instrument cluster back out, took it apart, manually moved the speedometer needle, it stuck at around 70 and would not return to zero. Apparently the last time I took the instrument cluster apart I tightened the case screws too much since the needle moved freely depending on pressure of the spedometer back plate. Re-assembled instrument cluster, everything seems to work fine now, will probably do another speed test.
Good to hear. It sounded like a speedo cluster failure or problem from the beginning. If the vehicle speed sensor is faulty, you will have all kinds of drivability problems, the transmission will shift erratically for starters.
VIPNiSS
03-04-09 03:34 PM
