4ES-2003 ES300 aftermarket stereo install
Just purchased my 03 es and wanna replace the stock stereo since the cd player is jammed. I almost have it all figured out.
I need to get the double din mark levinson faceplate
To remove the factory i need to first unclip the ac controls and remove them what's the best way to unclip the dash parts?
Then there are 2 screws I need to remove under the stereo unit and it should wiggle out
Once I get my new stereo in I need to use a couple of metra trim pieces to make up for the extra room. metra part # 95-8202
Then it comes to wiring. I've found no wiring harness that works although I read that the metra TYT0-01 worked for someone. Any suggestions?
And then the issue of the factory amp. Will I have to bypass it? If so will I lose my sub? Whats the best thing to do here?
Is there a DIY somewhere for this model? If so, I haven't found it yet
Thanks
I'm wanting to install the JVC-KW-XR810
Thanks
Here's a few DIY's that'll help:
https://www.clublexus.com/forums/es3...o-install.html
https://www.clublexus.com/forums/lex...l-success.html
jakebot88
07-26-15 05:05 PM
Havok13154
05-14-08 11:47 AM
