Pic of my ES with lowering springs
lowered with KG/MM springs along with KYB GR2 shocks.....
welcome any comments....
http://photos.yahoo.com/bc/mcv204me/...Photos&.view=t
good / bad....
after i installed the springs... i knw i should get the racing springs instead (with lower drop)
handling it totally improve over the stock sup...
good / bad....
Your ES300 is exactly like my friend's, and looks very nice with the rims. We just lowered my friend's '98 also, but with the TRD/Bilstein setup. Now, he just need to get some 17" over the stock chromies.
Luc
Luc
Originally posted by MCV20
how much drop is your friends ES300..?
Luc
Luc: holy.. that is 1.2 drop from the pic... i think that is way more than 1.2
92Es300 5sPd: to answer your question... it is 17" with 215/45-17 tires....
How is the ride? Is it more stiff and also are you bottoming out over large potholes or bumps. I just ordered a set of toyico struts. I plan on keep the stock springs as I am not too concerned about lowering the car. Let me know
Thanks
Thanks
Thanks
Thanks
Luc
Originally posted by EGainer
wait, how do i get to the springs? can i still use my spring clips on them?
Luc
wait so i need to prep the springs somehow before i use the clips. or can i just take off the wheel and put some weight on the axel so the spring compresses some... like putting it on a cinder block
I'm not sure what your spring clips are. Here is what my compressor looks like when I did any suspension work.
Putting cinder blocks under the axle will NOT compress the springs over time, as the springs keep their recoil fairly well.
Luc
Luc
i didnt mean compress the springs over time, i mean just compress them to help me get the clips on. i was going to put them on without taking the springs off
