2000 Es300 Foglight Restoration
After 11 years the foglights on my Es have become very pitted by rocks and such, so I decided to sand the headlights down to a like-new state.
Products Used:
100 grit sandpaper
320 grit
800 grit
1000 grit
2000 grit
Meguiars plastic polish
Black and Decker buffer
Meguiars Cleaner Wax
2-3 hours time
Bench Vise
Step One: Put your headlight in the bench vise and tighten it just enough so it won't move around when your sanding.
Step Two: Sanding using 100grit on a sanding block to make sure you don't cause any flat spots in the plastic. This is where most of the plastic will be removed and a little effort will be need to sand out all of the pits, and some may not even be removable because of how deep they are.
Step Three: Sand using 320 grit until the 100 grit marks are gone. Spend a lot of time on this grit as it is important so that you can get the deeper scratches out that the 100 grit will leave behind.
Step Four: Wetsand using 800 grit paper until the scratches become finer
Step Five: Wetsand using 1000 grit paper until scratches become finer
Step Six: Wetsand using 2000 grit paper until the scratches become almost non-existant. It will still be dull after using 2000 grit, but the polish and wax will take care of that.
Products Used:
100 grit sandpaper
320 grit
800 grit
1000 grit
2000 grit
2-3 hours time
Bench Vise
Step Seven: Apply the Meguiars plastic polish to the lense and let dry for about 5 minutes, then buff off using a power buffer for best results, but hand buffing should work too. I repeated this step twice for better results.
Step Eight: Apply the Meguiars cleaner wax to the lense and let dry, then buff off using power buffer for best results. I also repeated this step twice for the best results.
Step Nine: Clean up all the water or polish left around the foglights.
Step Ten: Re-install and admire your new looking shiny foglights![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
The second to last photo is a comparison photo, refinished on top, original on bottom. The other two are both finished shots
By oem casings you mean buying brand new foglights? I'm thinking the difference in cost would be ALOT seeing as this only cost me about 3 dollars as I had everything but 2000 grit already. If you were to buy everything besides the buffer it would probly only be about 20$ and I'm sure the foglights are over 100$ a piece.
Wow thanks for the info MrBooby! Makes me feel even better! And @gray_es300 yeah im sure there are simplier ways to get lesser results like you said, but this method gave me, imo, great results! Definitely worth the time, effort, and money.
*bookmarks thread*
Holy wow - my fog lights are not as bad as yours, with some elbow grease and time this will be worth the effort. I nearly bought new lights a few weeks back and gasped when the parts guy told me it would be nearly $400 for a set.
will post pics of how to remove foglights on sunday when I get back, stay tuned! Can also post pictures of how to remove front and rear bumpers, and lower door moldings since I will but putting those all back on the car on monday. If anyone is interested let me know!
Here you go.
https://www.clublexus.com/forums/es3...7-99-more.html
