Newbie here-The dash light showing a car with lines coming out of the back?
On a 1992 es300...Can anyone please tell me what this light means? It just came on today and I never got a manual with the car when I bought it. Can anyone also tell me where I can get a manual for this year/make (if possible). Thanks so much!
That's the traction control light, means the traction control system is offline. You can typically find a manual on ebay pretty cheap. Too bad, I have an owners manual for a 2002 and 2003. In any event, if it's on all the time there is a problem with the traction control system. You will need to get the codes pulled and see what's up.
that light means one of your brake lights is out. put something heavy on the brake pedal or get a trustworthy friend to apply pressure to it and check that all of your brake lights are working. if just one of the bulbs from the right, left or middle brake lights are out that light will come on.
enter your car info into this website
http://www.sylvania.com/ConsumerProd...lacementGuide/
then find the bulb number for the burt out bulb and replace. good luck
Thanks guys, yes it is the burnt light one-thanks for the pic myes300yea. I backed up to a window and low and behold it is the top right (passenger side) light! So I can figure out which bulb that is and find one at an autozone, or do I have to order one special for this year?
Parking light
168
168ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
1157A
1157ALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear turn signal
1156
1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
1157
1157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
1157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Stop light
1157
High mount stop light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
License plate
168
Back up light
1156
168
Front turn signal
1157A
Rear turn signal
1156
Tail light
1157
Stop light
1157
921
License plate
168
Back up light
1156
Khalendar
06-18-13 11:19 AM
