Access to diagnostics via CAN or CAN-HEX
Hi;
I hope you can answer my question. I have two 2008 VW Touaregs and as such have a diagnostic monitoring kit that enables me to get into the innards of these normally autistic beasts. My father has a 04 or 05 Lexus ES300 that has a MIL light on. I'll be traveling to Spain where he lives and was wondering whether :
1) Lexus supports the CAN or CAN-HEX interface to get into the diagnostics and determine what problems and codes are pending. Meaning I would try and use my VAG-COM OBD-II interface (with CAN-HEX) on the Lexus.
2) Is there a similar program to the VAG-COM on a Lexus that would run on MAC or XP SP2 that is available to the public?
Thank you for your help. Best from Alaska
If anyone can help me, here are some more details of what I'm looking for:
1) Does the ES300 support ISO 9141-2 (the old K-Line "CARB" protcol), ISO-14230 (KWP-2000 on K-line), or ISO 15765 (CAN) for OBD-II.
or
2) Does it work on the either of the flavors of SAE J1850 for OBD-II which my scanner does not support.
Thank you in advance for any help
aksiberian
or
aksiberian
