HELP is needed please
i just put hids in my 2001 es300 coach edition and they dnt seal right the stock holagen bulbs plugged into a round plastic piece that got seal by the round gramet but with hids they dnt use the stock plastic piece so one they dnt get held right with the metal clip an two they dnt get sealed a all by the rubber gramet!!!!!! is there anyone out there that has reto fited them good enough to were they dnt get all foggy in the headlight cuz im sure im not the only one with this prb.
Yes, this is tricky. Two ways, buy the adapter, or dremel your old bulb holders to fit the wiring, like this [i did this]:
![](http://www.zarizcycle.com/components/com_jshopping/files/img_products/full_a713a10bae912b2f71eba3082c150d59.jpeg)
The seals?
Easy, re-use the seals/wire holders that came with your hid kit, cut them to size [round part] and place them inside the dust cover, so the cover sits like oem, and bulb fit like the oem halogens; exposing only the wires [two will be pulled out for the ballast portion.
**i used to have a jerry-rigged version that retained the oem holder, and 'bent' clips. This one needs much less modification, and the clips don't need to be bent at all. If anything a little bit towards the holder by 1/8" [if that]:
![](http://i622.photobucket.com/albums/tt307/w300sale/f7daf75e.jpg?t=1314585689)
The seals?
![](http://i622.photobucket.com/albums/tt307/w300sale/3a4286a0.jpg?t=1314585692)
great were can i find the adapter?? an i have philip bulbs an on the gasket side were the bulb is is the two wires tht hook into the oem harness an on the othere side of the gasket were the engine bay is is the two wires that hook into the ballast!! how do i get those to wires for the oem harness outside the seal with out it being not sealed if that makes any sense??
the pics helps alot and i thank you for the info but the only thing i cnt see in the pic is were and how to feed the two wires through to plug into the oem harness???
Davin Huang
05-18-02 09:52 AM
