"Brakes" switch
Old 08-29-11, 08:07 AM
chuckerst
chuckerst's Avatar
Default "Brakes" switch
does anyone know where the "brakes" switch is-(that activates the dash warning light)-I think mine is defective or needs adjustment-thanks
Old 08-29-11, 10:35 AM
EEngineer
EEngineer's Avatar
there's no such thing.
if your brake light is on, your brake pads probably needs replacement.
Old 08-29-11, 12:24 PM
BDSL
BDSL's Avatar
Check your brake fluid level in the reservoir.....
Old 08-29-11, 01:42 PM
EEngineer
EEngineer's Avatar
^low brake fluid level is caused by overly worn pads. the pistons needs to push more to have the pads touch rotors, so it seems like there is not enough brake fluid. however if the pads get replaced, the brake fluid levels will go back up to normal again.
Scott610
IS F (2008-2014)
08-01-17 12:13 PM
Francis
RX - 1st Gen (1999-2003)
12
03-05-12 05:14 PM
Way2FLY
05-16-11 06:54 AM
Lexbox
Suspension and Brakes
09-27-06 08:06 PM
SLVRGS
GS - 1st Gen (1993-1997)
11-26-03 06:53 AM
Quick Reply: "Brakes" switch
