2000 ES300 Heated Seat Blue L.E.D. Light Conversion
sorry ahead of time is this has ever been posted and/or if this is not posted in the correct form. i just haven't seen anything posted for the es300 with pictures.
I'm pulling out the switch for the heated seats to change the light from a halogen to a LED. Very nervous about this so if there are any mistakes please feel free to point them out so that next time i post i can correct as needed :-)
the switch looks liek this. the brown thing there is the twist clip. turn it counter clockwise and turn it over and it should fall out.
![](http://i1232.photobucket.com/albums/ff371/Amanda_Meza/015.jpg)
thi is how it will look pulled out. notice how the bulb wire is wraped around the socket base. thats how it makes contact with the coper on the switch.
![](http://i1232.photobucket.com/albums/ff371/Amanda_Meza/016.jpg)
i used a 5mm LED sanded down to almost the size of the original light that was in it's place. side by side to a unsanded LED. above the LED is the original light that was in there.
![](http://i1232.photobucket.com/albums/ff371/Amanda_Meza/017.jpg)
i used a 560Ohm resistor and a 3V Led. solder the resistor on the positive side of the LED and rewraped the wires how they were originaly on the twist clip/base. it should look like this side by side. it will be a tight fit but it will go back in. if it does not you'll need more sanding on the LED.i put the light back in resistor pointing torward the switch.
![](http://i1232.photobucket.com/albums/ff371/Amanda_Meza/018.jpg)
i took this in the daylight but you can see the blue a little. if you did everything correctly it should turn right on. if not pull the light out do one half turn, insert the light back in and it should light up then.
![](http://i1232.photobucket.com/albums/ff371/Amanda_Meza/019.jpg)
a light to close but you can see the blue more
![](http://i1232.photobucket.com/albums/ff371/Amanda_Meza/020.jpg)
![](http://i1232.photobucket.com/albums/ff371/Amanda_Meza/021.jpg)
and there you have it. ugly green to deep dark blue. this will take 30min or so to do one. so far i have done my left and right door switch to blue and hope to change every light i can to white or blue.
