LED problem
I installed LED's in my '94 ES and ran into a huge problem. I replaced the reverse lights, license plate lights, and both interior dome lights. Then I found out that my whole electrical system was malfunctioning. Only a few electrical things and lights worked at a time, which changed every time I tried the ignition, and the car won't start. Any ideas what happened, or how to fix/prevent it in the future?
LED's are polarized, try flipping the LED's around. Orrrr, LED's usually have a lower amperage, so if the parts you replaced with LED's are run by a relay the relay might not be detecting the LED's so you may need to change the relay to an electronic/digital one.
Your most likely problem is in the dome light area. You may have blown a fuse. Double check your dome light LED installation carefully and check the related fuse.
Phil
Phil
chrispy
05-20-10 09:14 AM
