Turbo questions
The problem with this idea is that most people who think of it really have no idea how much air gets pumped by the engine during its normal operation. The engine acts as a big air pump and is capable of moving huge volumes of air all on its own. With that in mind, any electric fan that you place in the path of the intake is only going to act as an obstacle to efficient airflow and not provide any level of boost whatsoever. In order to provide boost, the fan has to be able to force more air through the intake than is already being sucked and that's simply not going to happen with some off-the-shelf computer fan or bilge exhaust blower or whatever else you've found or had marketed to you.
Electric Supercharger
Now that you realize how futile the idea of an electric supercharger is, consider the dangers. If you place something in the intake path between your air filter and the engine and that thing isn't made to be there, you now run the risk of having it break and send unfiltered pieces into your engine, potentially causing catastrophic failure. I would hope this is more than enough to discourage experimentation in this area.
As a general rule, if something seems too good to be true it generally is. Modifying a car to add power isn't a cheap endeavour and most of these sorts of shortcuts will only end up burning you in the end.
Interestingly, the company from whom I got that image above even has a small disclaimer on their site with a list of cars that showed no gain from their units. The list included GM's 2.4L engine in both the Grand Am and Cavalier Z24. I suspect it likely includes all cars from ripped-off customers who bothered to get the system dyno tested.
http://www.wildweasel.ca/HowTo/Auto/eturbo.aspx
5% Club. Killing it!!!
I'm just gonna keep it low-budget and buy one of these:
http://www.bestelectricsuperchargers.com/
I know that the website is lying and I won't actually get 50hp from this piece of crap, maybe 10 at the most. But if I combine this with my existing ram-air intake and get a custom exhaust job, I can maybe pull off 30hp (?).
Learn the hard way i guess...
I can't believe I'm actually reading and responding to this post.......
funny how age changes you, 10 years ago, i might have actually thought abt this for a second, now i wont give it a second look! there are way nicer things to spend your money and time on in this world! i know i know, "sound like your grandpa" bla bla bla, but hey, truth is the truth!
Trust me, I know. I make barely over minimum wage, and work about 20 hours a week. There is NO WAY IN HELL I'm dropping $4000 for some over-hyped supercharger. That's why I wanted to get a used OEM supercharger from eBay for like $300. But I'm gonna ask some professionals to see if that's even possible.
^he did, and since the s/c was used, it needed a rebuild after about a year with the twincharge setup.
and then the s/c came off and T51 SPL was put on.
he's putting the s/c back but he's too busy making money...has no time
it's a bummer ....my exhaust job got pushed until mid october...
TS, turbo or s/c is a waste of time and money on the ES platform. If you have the funds, go ahead, but you said you wanted to keep it simple. You want performance? Just keep up the maintenence and your lexus will perform outstanding or next to manufacter spec. Forced induction is no joke, you have to pay to play.
Case in point.... don't do anything to the car. Keep driving it until you have the funds to support modding habits.
There is no inexpensive way into modding.
