2000 ES Turn Signal?
Hello,
Was wondering if anyone experienced the same issue. My right turn signal on the dash does a fast flicker as if one of the bulbs were out, yet while looking both the front and rear turn signal indicator bulbs are flickering on/off just as fast, so the bulbs are not the issue. The left works as should. Any ideas as to what may be causing this? If relay is there a separate right and left?
Thanks for any help.
Left and right (and emergency) all work off of one relay. Did you replace a bulb? The speed of the flicker works off of an expected amount of resistance. If the resistance drops it clicks faster. If the bulbs are both good this typically means a non-spec bulb was used. Those who like to replace with LEDs can run into this issue.
i had a problem with left turn signal going like crazy, i found the service bulletin that requires replacement of the socket for the bulb. It works. The part cost 8.00$ at the dealer. see attached document.
xspsi6
Performance & Maintenance
04-19-12 09:42 AM
