Alternator Wiring Diagram
need to know, planning to install a HO alt, and want to know the paths of the hot wire of the alt. Looks like it goes into the engine block, and comes out on the other side for the battery connection. . a little confused. thanks. got a 96.
^yes sir you are indeed correct!
thanks to you, i had to find out for myself. looks like the body of the alternator is the ground. since it is connected to the block anyway.
![Name: electricaldiagram.jpg
Size: 54.7 KB](https://www.clublexus.com/forums/attachments/es-1st-to-4th-gen-1990-2006/433463d1501361567-alternator-wiring-diagram-electricaldiagram.jpg)
heres a picture in a 2001 camry: http://www.powerbastards.com/images/022310154653.jpeg
The wiring diagram didn't help me understand like i should lol. I was thinking to just leave the existing power wire and also adding a 1/0 wire to the battery (so i will not have to integrate other wires) do you think this is a good idea??
MarcusMIA
Performance & Maintenance
12
10-03-16 09:46 PM
steveo81
09-15-08 10:56 AM
06, 1996, 300, alternater, alternator, alternatorbattery, connection, diagram, es, es300, is350, lexus, p5700, pioneer, wiring
