ES300 Passenger and Driver Seat Back Interchangeable?
Hello -
I have a 2000 Lexus ES300 and the leather drivers seat (back part, not seat bottom) is starting to really show wear.
Is there a way I can take the seat back (enter set back, not really wanting to remove the cover) from the Driver Side and exchange it with the Passenger side?
The bottom of the seats are fine so I don't want to get involved in changning out the seat bottoms unless that is required.
Your help and support is greatly appreciated in advance.
thanks
kp
thanks
kp
Also, and more importantly, the side air bags, which are located on the back part of the seats (on the door sides) will end up in the wrong location if you switch the backs of the seats around.
So the answer is that they are not interchangeable.
Phil
Phil
Glad I checked. I did not think about the SRS...
Can I change the seat covers? that is, take the top of the seat cover off the passgenger and switch it with the drivers side.
Also, how hard is this to do? I don't want to end up with a bigger mess than I already have.
thanks in advance.
thanks in advance.
thanks in advance.
thanks in advance.
Your best bet will be to have the seat leather repaired professionally. It will look like new and is not that expensive.
There are many You Tube Videos on how its done
Post a picture of the damaged seat if you can.
Thanks for the help...
Here is a picture. would any of these products work? Note: it is not cracked, but just about worn through.
![ES300 Passenger and Driver Seat Back Interchangeable?-seats.jpg](https://www.clublexus.com/forums/attachments/es-1st-to-4th-gen-1990-2006/224971d1461116826t-es300-passenger-and-driver-seat-back-interchangeable-seats.jpg)
I just grabbed a few that were listed on eBay.
http://www.leatherrepairkits.com/
http://cgi.ebay.com/ebaymotors/Lexus...item27afc3d9e0
http://cgi.ebay.com/ebaymotors/TAN-C...item2a0d9b1ded
http://cgi.ebay.com/ebaymotors/PERMA...item2eb4802935
MPLexus301
11-18-10 05:36 PM
