sway bars?
sway bars?
im new here and i did a search but could not fond anything useful i am looking for some sway bars for my 1994 es 300. links would be really nice guys. i am also looking to put new front rotors on her to a long with some minor performance upgrades can i get some suggestions on thease thanks guys
Are you replace the OEM sway with OEM sway or thicker one?
I am sure you can find it, but you will need to update the bushings as well to take on the larger OD of the thicker sway bars.
I did this on my 911, simple swap.
Well, it appears even TRD does not make larger sway bars for our year, only rears for 02-08.
If you want to take corners faster then you may want try other things:
Stiffer bushings on the sway Bar i.e. poly bronze or other harder composite type bushings.
Stiffer drop links,
Camber Brace/Bar
More Negative Camber, front and back.
Lower all around.
Stiffer Struts all around
Stickier Soft Tires i.e. Dunlap Star Spec 1's
Caveat, doing this will harden the ride and wear out components faster and premature tire wear.
Stiffer drop links,
Camber Brace/Bar
Lower all around.
hahaha, you guys really should go do more research
TRD rear sway bar for the Solara fit fine, but it's discontinued and hard to find
whiteline makes rear sway bars as well, both Solara and Avalon ones fit. Avalon's is 20mm, thicker than the Solara's. that's the one i have right now.
you can check out the thing in my thread in my signature.
Well if you want to keep the OEM ride then try the more Negative Camber Adjust and rear sways mod.
She will ride the same but you will be able to take the corners faster. The only thing is the tires will wear faster on the insides.
