Nitrogen gas filled...
has any one has nitrogen gas filled up in their cars instead of regular oxygen gas??? i have reading that its better?? any ideas??i have been thinking of changing it..
Also what happens if it blows out by nail..can i fill it up again with O2 air?
Approx 70% of what you breath is nitrogen. When they filter nitrogen from the air to put in your tires it is better because it filters out any moisture or other contaminants. Nitrogen in and of itself is a slightly larger molecule and is a very stable gas. It will not leak out nearly as fast as air and it does not react to temperature nearly as much as oxygen. Is it better? Yes it is. Is it a major night-day difference? No it's not. All things being equal I'd prefer it but I wouldn't lose sleep if I chose not to as well and certainly wouldn't pay very much. If you get a flat or a low tire you can fill it with regular air.. as stated above air is approx. 70% nitrogen.
I used to have it in my tires on my Lexus, I noticed absolutely no difference, none. So in theory it is better, in practice I can't notice it, and how am I supposed to maintain my tire pressure with nitrogen? How many people have a nitrogen tank?
If you can have the tires filled and maintained with nitrogen for free, then go for it, otherwise don't bother.
i think i agree with ya and that was my concern too..for ppl like me who check my pressure everyweek and carry a compressor dont need nitrogen...but for ppl who dont value/care the importance of proper tire monitoring should go for nitrogen
Well, my engineer friend said a funny thing to me,
How do they install the tire, wet or dry?Huh? he explained: Unfortunately the idea behind nitrogen in tires was to eliminate the possibilities of water developing in the tires but the installation process negates the potential benefits.
Below is an extract on the subject from a recent Consumer Reports Magazine.
"Pass on the nitrogen. Many car dealers and tire retailers will tell you adding nitrogen to your tires in place of plain-old air will help maintain the proper pressure longer. That may be true but whether you use nitrogen or air, check your tire pressure routinely. Our tests showed that tires will lose pressure whether filled with nitrogen or air. If nitrogen filling is free, there is no harm in using it, but why pay for it? Bottom line: there is no substitute for doing proper pressure checks."
I use nitrogen on my race tires since it is important to maintain a precise tire pressure for best performance. As the track and ambient temperatures rise, the nitrogen filled tire pressures are more stable.
As for daily driving, if you either have TPMS or you check your tires regularly, then there's not much of a benefit.
I haven't been aware of any wheel with 2 valve stems??
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Unless you have the ability to suck all the air out and create a vacuum, there will always be some mix of oxygen and nitrogen, even with 2 valve stems. As long as there is 0 lbs of pressure before the tire is inflated, then fill the tire up with nitrogen to say 50lbs then the oxygen ratio will be very low. Then you can deflate the tire to the desired pressure, say 32 lbs and that should be sufficient.
Hello; I've had Nitro Fill in My 20's on ES for almost two years and I get them checked every 3 months or so, and lose only 2 pounds each tire. What I like is lifetime fill I just go in they check the tires and fill them.Also better ride with these tires,
People ride in my car say your car rides so smooth .Anyway that's my opinion.Also helps gas mileage,I average 19-21 MPG depends where I go. Thanks,Bobby
Hello; I've had Nitro Fill in My 20's on ES for almost two years and I get them checked every 3monthes or so, and lose only 2 pounds each tire. What I like is lifetime fill I just go in they check the tires and fill them.Also better ride with these tires,
