1996 lexus es300 turn signal problem.
Hi I have a 96 lexus es300 and my turn signals and my emergency flashers stopped working. I replaced the signal flasher relay and that did not fix it. I was looking for some suggestions on what might be causing the problem? Thanks for the help.
where is the turn signal flasher located?
Did they all go out at once, or did it happen one by one? I had this problem with the two front turn signals and thus affected my hazards as well. To remedy the situation i grabbed some sand paper and removed the bulbs from the bulb connectors. Then i scrubbed the connector pins down, they were coated with carbon deposits(black crud that hampered the connection) and all was well after that. Give it a try, although if all four went out at the same time it might be something electrical besides the relay.
