Overheating on rebuilt engine
Hoping someone can help me decipher the culprit with this gremlin. I have an ES300 1995 1MZFE engine.
My car blew a head gasket a few months back. I decided to rebuild the engine myself for the experience and to save $$$. Its been a long road to today when I fired it up and was quite happy it turned over. I have one problem, though. The car is overheating.
I have a new radiator and a new thermostat. I did not check the waterpump though. I am suspicious now it may be bad. I was told that it had been replaced a few years prior when I bought it. I am also hearing a slight bad bearing sound coming from the front of the engine.
Can the water pump freeze up and the timing belt still run? Wouldn't I smell rubber burning?
Is there a way to definitively tell if the WP is bad with out removing everything to get at it?
Symptoms:
Overflow is boiling water
Engine is running hot
Bad Bearing sound
Thanks in advance!
Symptoms:
Bad Bearing sound
Thanks in advance!
You may just have air trapped in the system, do you have a Lisle Spill Free Funnel? Great thing for getting all the air out. How long does it take for the engine to start to overheat?
I am thinking it may be the props that disintegrated. The overheating starts within a couple of minutes.
When the rear head went out it was 105 outside and the upper plastic radiator tank had a hole in it from all the heat. It makes since that the water pump gave out somehow. I should have just changed it out. I have one on order.
andyman32
03-17-13 07:58 AM
SonyaSC400
Performance & Maintenance
15
07-07-07 06:02 PM
