Broken Keyfob (1/8" gap in key ring area)
1998 ES300
I have a broken plastic key ring area for my 1998 ES300 remote opener keyfob. Is there a way I can repair this so that the keyfob (remote device) will accept key rings? Other than the broken key ring area, the keyfob works fine. Both the lower and the upper black plastic key ring areas are broken so I'd need to fix each one. There's about an eighth of an inch+ gap at the top of each key ring area that has broken off. I've thought about a small washer but didn't know if that's the best approach.
TIA!
TIA!
kfit103710
16
12-13-13 11:03 AM
