ES300 front suspension bearing replacement
Old 12-04-11, 06:38 PM
MKLEX
Registered User
MKLEX's Avatar
Default ES300 front suspension bearing replacement
has anyone replaced the bearing in front suspension? I believe bearings in both front struts are shot. I don't know if it is recommended to replace the seats that go under the bearings. Could you tell me if I need to replace the coil spring seat and the support assembly that goes on top of bearing?
I appreciate your help.
Old 12-07-11, 10:18 AM
pauloil
pauloil's Avatar
If you are going to pull the strut for Bearing do the mount also, and depending on mileage, consider new strut
Old 12-07-11, 03:18 PM
yeldogt
yeldogt's Avatar
If original -- I would replace the whole upper strut mount -- you will have to look at the spring seat -- they are often fine.
I would also price out the OE mounts -- If you are going to keep the car the few extra dollars well spent. Its not an expensive part ..... its the labor and the alignment.
Old 12-07-11, 08:25 PM
01LEXPL
01LEXPL's Avatar
Mileage?
I did all four of mine, even though the backs were only toast. It will be a matter of a few miles before the rear gives out, so why pay twice for the same work? I say you do what i did get the whole suspension set from www.rockauto.com [stupid cheap when compared to anywhere - even eBay], including monroe quick struts [has all the components, no need to compress old spring onto new strut & new mounts. its ALL there, literally drop them in], and new bushgings [40$ front & back] & endlinks [<100$ front & back] Those QuickStruts should be in the 550$ range...
xelphor
17
11-07-11 05:43 PM
rtklein
11-01-11 11:07 AM
decypher
04-14-11 07:50 AM
JAB
RX - 1st Gen (1999-2003)
09-29-08 01:53 AM
thang tran
09-20-08 01:38 AM
Quick Reply: ES300 front suspension bearing replacement
