View Poll Results: Do you have an exhaust installed?
Yes - Happy with it and satsified.......etc
43.75%
No - Dont want one, bad idea....etc
56.25%
Voters: 16. You may not vote on this poll
Exhaust.. Poll
most everything has been mentioned
but the piping is 2.5 up to the resonator then goes to 2.25 to the muffler so if doing a change remove the piping from the resonator back to a 2.5 inch pipe stainless steel and mandrel bent to reduce the bulges and curves for backpressure issues
the larger an exahust tip the louder the noise or fart
even well know companies have these crappy sounding exhausts
the wider ( or the more its design gets away from being a perfect circle)
an exhaust tip is the more reduction properties it has against resonance
a speaker boxes perfect dimensions should be a ball
fo resonace which inceases sound
i have a 4 1/2 inch wide tip but only 1 1/2 inches higher
a very deep sound ask mcv20
he has a round one
also the wider the muffler the better not just the tip
just a thought to ponder
and besides if you change the piping
you can get rid of that funny bend under the car that looks like yours is broken
later
he has a round one
later
why am i not surprised
you agree to disagree
all together it is a greater sum of all the parts but the biggest noise influence
is the tip
belive what ever you want
is the tip
