Lower Control Arm and Ball Joint Replacement
had to replace both control arms on my parents es330. It was a total PITA to say the least. We had to remove the engine mounts on both sides and used a jack to lift up the engine so we could get the angle to remove/install the control arm. Took a total of 4 hours to get both sides done. By far the dumbest design ever.
I'm sorry to say I think you really got gouged on this job, $1300 to replace a single control arm is highway robbery. Regardless of what the "book" says, I GUARANTEE you the mechanic didn't completely pull the engine out to do that job.
For a single side to be done, somewhere around $300-$400 total would be my best guess.
Marle (03-25-21)
Posting this in case someone is viewing this thread. My '06 ES330 w/ 130K miles (I've owned since 90K) had its front wheels out of alignment (steering wheel has to be offset clockwise about 10 degrees for car to be driven in a straight line). My passenger tire has excessive outer camber wear also. I raised the car and noticed no play in the outer/inner tie rods. The driver lower control arm ball joint looks like it has a tear and there was a bit of ball joint grease around the base so I assume that's up for replacement? I have done zero suspension work in the last 40K miles I owned the car and I don't know if anything was done prior to that.
Now, the interesting thing is that the lower control arm (which, from this thread, is a HUGE pain to replace) actually attaches to a smaller assembly that has the ball joint. In effect you can replace the lower control arm ball VERY easily by removing three easy-to-get-to bolts that bolt the control arm to the ball joint "holder". This ball joint is $19 at rockauto, and is extremely DIY from the looks of it. Most will need to replace the ball joint as part of maintenance (with it being a wear part). Offcourse a damaged control arm is more extensive. Even then as somebody said the control arm itself is only $40.
www.youtube.com/watch?v=Twt47cvQFjY
I had to change an axle so changed the right (pass) control arm. Part was $80, and if this was all I had to do this is a 2 hr job. Hardest part was having to raise the engine to get enough clearance to remove the motor mount as one of the bolts for the arm is behind it. Other than this I cannot see the high cost. Glad you for it fixed and its behind you. This was on an ES 330.
SNiiP3R
02-26-20 10:31 AM
arms, ball, ball joint, bent, club, control, control arm, cradle, curb, es330, gs, hit, joint, jointreplacement, lexus, replacement, rx
